Ana içeriğe geç
Black and Decker PS1800 Transmission Replacement
Neye ihtiyacın var
  1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: adım 1, 2 resimden 1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: adım 1, 2 resimden 2.
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Transmission Replacement: adım 2, 1 resimden 1.
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: adım 3, 3 resimden 1. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: adım 3, 3 resimden 2. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: adım 3, 3 resimden 3.
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Transmission Replacement: adım 4, 1 resimden 1.
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Transmission Replacement: adım 5, 2 resimden 1. Black and Decker PS1800 Transmission Replacement: adım 5, 2 resimden 2.
    • Remove the motor from the transmission assembly, as pictured.
  6. Black and Decker PS1800 Transmission Replacement, Transmission: adım 6, 3 resimden 1. Black and Decker PS1800 Transmission Replacement, Transmission: adım 6, 3 resimden 2. Black and Decker PS1800 Transmission Replacement, Transmission: adım 6, 3 resimden 3.
    • Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
  7. Black and Decker PS1800 Transmission Replacement: adım 7, 1 resimden 1.
    • Align the new transmission gears with the motor’s gears.
    • Reattach the transmission and motor by rescrewing the initial screws.
  8. Black and Decker PS1800 Transmission Replacement: adım 8, 2 resimden 1. Black and Decker PS1800 Transmission Replacement: adım 8, 2 resimden 2.
    • Reconnect the torque adjuster to the transmission by following the procedure seen in step 6.
  9. Black and Decker PS1800 Transmission Replacement: adım 9, 1 resimden 1.
    • Reconnect black and red wires onto the motor and place the motor, transmission and torque adjuster back onto their initial location.
  10. Black and Decker PS1800 Transmission Replacement: adım 10, 1 resimden 1.
    • Reconnect the clamshell.
    • Press trigger to make sure the new transmission works.
    • Press and hold the clam-shell to assure it will not drop while testing.
Sonuç
David Nawl
279 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,470
