Giriş
If the motor of the drill stops working, this guide will show you how to remove the motor of the black and decker Pivot Plus PD600 whether for repair, or for other use.
Neye ihtiyacın var
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
If my motor try to turn is there anything I can do to fix-it? :)
