Ana içeriğe geç
Black and Decker Pivot Plus PD600 Pivot Button Disassembly
Neye ihtiyacın var
  1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: adım 1, 2 resimden 1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: adım 1, 2 resimden 2.
    • Locate the pivot button screw labeled with a lock symbol.
    • Remove the screw with a Phillips #1 screwdriver.
  2. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: adım 2, 2 resimden 1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: adım 2, 2 resimden 2.
    • Set the screw to the side.
    • Remove both sides of the button from the screwdriver.
    • You will be left with three pieces: a black piece with a lock on the front, a circular orange piece, and a spring.
Sonuç
Ryan Angelich
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G15
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 1,252
