Ana içeriğe geç
Black and Decker SS12C Battery Replacement
Neye ihtiyacın var
  1. Black and Decker SS12C Battery Replacement, Battery: adım 1, 3 resimden 1. Black and Decker SS12C Battery Replacement, Battery: adım 1, 3 resimden 2. Black and Decker SS12C Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: adım 2, 1 resimden 1.
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: adım 3, 3 resimden 1. Black and Decker SS12C Battery Replacement: adım 3, 3 resimden 2. Black and Decker SS12C Battery Replacement: adım 3, 3 resimden 3.
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: adım 4, 2 resimden 1. Black and Decker SS12C Battery Replacement: adım 4, 2 resimden 2.
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: adım 5, 3 resimden 1. Black and Decker SS12C Battery Replacement: adım 5, 3 resimden 2. Black and Decker SS12C Battery Replacement: adım 5, 3 resimden 3.
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dalton Johnson
337 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 942
