Ana içeriğe geç
Black and Decker TO1303SB, TO1313B Heat Controls Replacement
Neye ihtiyacın var
  1. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Top Cover: adım 1, 2 resimden 1. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
  2. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 2, 1 resimden 1.
    • Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
    • On the TO1313SB, a Security Torx T15 driver is required — the screws have a center pin that prevents use of a regular T15 driver.
  3. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 3, 1 resimden 1.
    • Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
  4. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 4, 1 resimden 1.
    • Remove the 11.5 mm screws using a #2 Phillips screwdriver.
  5. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 5, 2 resimden 1. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 5, 2 resimden 2.
    • Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
  6. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Control Knobs: adım 6, 1 resimden 1.
    • Using two metal spudgers, pry the top control knob directly outward.
  7. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 7, 1 resimden 1.
    • Using the two metal spudgers, pry the middle control knob directly outward.
  8. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 8, 1 resimden 1.
    • Using the two metal spudgers, pry the bottom control knob directly outward.
  9. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Heat Controls: adım 9, 1 resimden 1.
    • Remove the two 5.5mm screws, that are holding the oven controls to the face, using a #2 Phillips head screwdriver.
  10. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 10, 1 resimden 1.
    • Remove the two 7.5mm screws, that hold the toaster controls to the face, using a #2 Phillips head screwdriver.
  11. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 11, 1 resimden 1.
    • Remove the two 5.5 mm screws, that hold the timer to the face, using a #2 Phillips head screwdriver.
    • The timer is removed so that the wires that need to be un-clipped from the heat controls are easier to access.
  12. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 12, 2 resimden 1. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 12, 2 resimden 2.
    • Press down the metal tab on the oven heat control connector using needle nose pliers and pull outwards to remove the connector.
  13. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using your thumb, carefully peel back the heat shielding from the connector on the toast heat control.
    • Press down the metal tab on the connector using needle nose pliers or tweezers.
    • Do not try to peel the heat shielding back too far; it tears easily.
    • Repeat for each of the three connections on the control.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alejandro Martin
351 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-11, Maness Fall 2015 Cal Poly, Team 5-11, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G11
4 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
I got to removing the “back” cover. Black cover perhaps? There seem to be silver tabs from the front silver facing that are defeating my attempts to remove the cover.
Joe - Yanıt
Hi Alejandro, could you tell me how to replace the heating elements. Or maybe just how to access them for better cleaning? Or maybe just suggestions on how to clean them while in place since they do rotate? Vinegar-water isn’t working. Thanks!!!
Ginny Lupo - Yanıt
Where can I get a new toast/ heater control unit?
Rick P. Weyersberg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 87
Her zaman: 7,628
