Ana içeriğe geç
Black and Decker TR1278B Top Cover Replacement
Neye ihtiyacın var
  1. Black and Decker TR1278B Top Cover Replacement, Top Cover: adım 1, 1 resimden 1.
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Top Cover Replacement: adım 2, 1 resimden 1.
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Top Cover Replacement: adım 3, 1 resimden 1.
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Top Cover Replacement: adım 4, 1 resimden 1.
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Top Cover Replacement: adım 5, 1 resimden 1.
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dominic Gamonez
233 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 76
Her zaman: 6,342
