Ana içeriğe geç
Black and Decker Toast R Oven Knobs Replacement
Neye ihtiyacın var
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: adım 1, 1 resimden 1.
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: adım 2, 2 resimden 1. Black and Decker Toast R Oven Knobs Replacement: adım 2, 2 resimden 2.
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: adım 3, 1 resimden 1.
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: adım 4, 1 resimden 1.
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: adım 5, 1 resimden 1.
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: adım 6, 1 resimden 1.
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: adım 7, 1 resimden 1.
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: adım 8, 1 resimden 1.
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: adım 9, 1 resimden 1.
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
Sonuç
To reassemble your toaster, follow these directions in reverse.
Bir başkası bu kılavuzu tamamladı.
Jonathan
320 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G10
4 Üyeler
Bir Yorum
very interesting post
James Evans - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 47
Her zaman: 5,150
