Ana içeriğe geç
Giriş
This page gives instructions for disassembling the Black and Decker WP900 6-Inch Orbital Waxer and Polisher to where the external casing can be removed from all internal workings.
  1. Using the plastic tool, detach the handle tab as shown.
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Remove the back panel of the external casing, leaving all internal components resting in the front panel. Remove the black handle from the main external casing. Remove the black handle from the main external casing.
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
    why the circular head wobbling, was it get loose, how do i fix it
    Naruto Antujipun - Yanıt
  5. Gently pull the power cord out from the control module. Remember, when reassembling the device, the black wire should be on the top.
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top.
  6. Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Once the motor has been removed, the external casing can now be replaced.
Sonuç
David Hutchings
101 İtibar
1 Kılavuz yazıldı
Takım
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S8G8
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
Adam Kinnett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 467
