Ana içeriğe geç
Black and Decker WP900 Motor Replacement
Neye ihtiyacın var
  1. Black and Decker WP900 Motor Replacement, Motor: adım 1, 1 resimden 1.
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Motor Replacement: adım 2, 1 resimden 1.
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Motor Replacement: adım 3, 3 resimden 1. Black and Decker WP900 Motor Replacement: adım 3, 3 resimden 2. Black and Decker WP900 Motor Replacement: adım 3, 3 resimden 3.
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Motor Replacement: adım 4, 1 resimden 1.
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Motor Replacement: adım 5, 2 resimden 1. Black and Decker WP900 Motor Replacement: adım 5, 2 resimden 2.
    • Gently pull the power cord out from the control module.
    • Remember, when you're reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Motor Replacement: adım 6, 1 resimden 1.
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel are attached to the motor.
  7. Black and Decker WP900 Motor Replacement: adım 7, 2 resimden 1. Black and Decker WP900 Motor Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
  8. Black and Decker WP900 Motor Replacement: adım 8, 2 resimden 1. Black and Decker WP900 Motor Replacement: adım 8, 2 resimden 2.
    • To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
  9. Black and Decker WP900 Motor Replacement: adım 9, 1 resimden 1.
    • With a large amount of force, pull the motor up and off of the wire coil.
    The pad itself have fallen while im using it, can i still fix it?
    leworx_13 - Yanıt
    The backing plate has drop can i still fix it? Please help
    leworx_13 - Yanıt
    Do we know where we can order this motor part?
    Grant Gattuso - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stefan Wolowec
128 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S8G8
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
John Bazmek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 2,262
