Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using the plastic tool, detach the handle tab as shown.
Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
Remove the back panel of the external casing, leaving all internal components resting in the front panel.
Remove the black handle from the main external casing.
Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
Using the Flathead 3/32" screwdriver, remove two 22mm screws.
Gently pull the power cord out from the control module.
