Ana içeriğe geç
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Using the plastic tool, detach the handle tab as shown.
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the back panel of the external casing, leaving all internal components resting in the front panel. Remove the black handle from the main external casing. Remove the black handle from the main external casing.
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Gently pull the power cord out from the control module. Remember, when reassembling the device, the black wire should be on the top
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel will be attached to magnet body.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the switch from the wires.
    • Remove the switch from the wires.
    • Gently, pull and release the two wired connections.
    • The switch can now be replaced. Be sure not to damage the two connections to the control module in the process.
Bitiş Çizgisi
Cameron
207 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S8G8
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 767
