Ana içeriğe geç
BlackBerry 7100g Keypad Cover Replacement
Neye ihtiyacın var
  1. BlackBerry 7100g Keypad Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Keypad Cover Replacement: adım 2, 3 resimden 1. BlackBerry 7100g Keypad Cover Replacement: adım 2, 3 resimden 2. BlackBerry 7100g Keypad Cover Replacement: adım 2, 3 resimden 3.
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Keypad Cover Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Keypad Cover Replacement, Housing: adım 4, 3 resimden 1. BlackBerry 7100g Keypad Cover Replacement, Housing: adım 4, 3 resimden 2. BlackBerry 7100g Keypad Cover Replacement, Housing: adım 4, 3 resimden 3.
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Keypad Cover Replacement: adım 5, 2 resimden 1. BlackBerry 7100g Keypad Cover Replacement: adım 5, 2 resimden 2.
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Keypad Cover Replacement: adım 6, 3 resimden 1. BlackBerry 7100g Keypad Cover Replacement: adım 6, 3 resimden 2. BlackBerry 7100g Keypad Cover Replacement: adım 6, 3 resimden 3.
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Keypad Cover Replacement: adım 7, 1 resimden 1.
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Keypad Cover Replacement, Keypad Cover: adım 8, 2 resimden 1. BlackBerry 7100g Keypad Cover Replacement, Keypad Cover: adım 8, 2 resimden 2.
    • Remove the keypad cover.
    • Insert the new keypad cover.
    • You are done replacing your keypad cover.
Sonuç
Tristan French
34 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G87
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,434
