Ana içeriğe geç
BlackBerry 7100g Screen Replacement
Neye ihtiyacın var
    1. BlackBerry 7100g Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Turn over your BalckBerry 7100g so that the back cover is facing up.
      • Locate the battery cover release button near the bottom of the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7100g Screen Replacement: adım 2, 3 resimden 1. BlackBerry 7100g Screen Replacement: adım 2, 3 resimden 2. BlackBerry 7100g Screen Replacement: adım 2, 3 resimden 3.
      • Push down on the release button with one thumb.
      • Slide the battery cover off with the other thumb.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry 7100g Screen Replacement: adım 3, 1 resimden 1.
      • Remove the battery from the battery housing by flipping up the top of the battery.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7100g Screen Replacement, Housing: adım 4, 3 resimden 1. BlackBerry 7100g Screen Replacement, Housing: adım 4, 3 resimden 2. BlackBerry 7100g Screen Replacement, Housing: adım 4, 3 resimden 3.
      • Locate the silver strip near the top of your BlackBerry.
      • Use a plastic opening tool to pry off the edge of the silver lining.
      • Slide the tool along the length of the silver strip to completely remove it.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7100g Screen Replacement: adım 5, 2 resimden 1. BlackBerry 7100g Screen Replacement: adım 5, 2 resimden 2.
      • Do not lose the screws. They are quite small and can easily be misplaced.
      • Locate and unscrew the four (4) screws using a T6 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry 7100g Screen Replacement: adım 6, 3 resimden 1. BlackBerry 7100g Screen Replacement: adım 6, 3 resimden 2. BlackBerry 7100g Screen Replacement: adım 6, 3 resimden 3.
      • The keypad cover may fall out of the housing when prying the housing apart.
      • Tightly pinch the top of the front and back halves of the housing.
      • Carefully pry the two halves of the housing apart.
      FixBot'a Sor
      Yorum Ekle
    4. BlackBerry 7100g Screen Replacement: adım 7, 1 resimden 1.
      • You can now easily remove the "guts" of the phone from the housing.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7100g Screen Replacement, Keypad: adım 8, 3 resimden 1. BlackBerry 7100g Screen Replacement, Keypad: adım 8, 3 resimden 2. BlackBerry 7100g Screen Replacement, Keypad: adım 8, 3 resimden 3.
      • Turn the "guts" over so the speaker is facing up.
      • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
      • Separate the battery housing from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7100g Screen Replacement: adım 9, 1 resimden 1.
      • Pull the keypad off of the motherboard.
      • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7100g Screen Replacement, Screen: adım 10, 2 resimden 1. BlackBerry 7100g Screen Replacement, Screen: adım 10, 2 resimden 2.
      • Locate the ribbon connector below the bottom of the screen.
      • Use a spudger to flip up the connector.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7100g Screen Replacement: adım 11, 3 resimden 1. BlackBerry 7100g Screen Replacement: adım 11, 3 resimden 2. BlackBerry 7100g Screen Replacement: adım 11, 3 resimden 3.
      • Locate the four (4) white tabs that attach the screen to the motherboard.
      • Carefully detach the tabs from the motherboard.
      • The screen can now be removed from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adriel Salinas
42 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G87
4 Üyeler
72 adet Kılavuz yazıldı
1Rehber Yorum
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 2,337
