Ana içeriğe geç
BlackBerry 7280 Logic Board Replacement
Neye ihtiyacın var
  1. BlackBerry 7280 Logic Board Replacement, Battery: adım 1, 3 resimden 1. BlackBerry 7280 Logic Board Replacement, Battery: adım 1, 3 resimden 2. BlackBerry 7280 Logic Board Replacement, Battery: adım 1, 3 resimden 3.
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Logic Board Replacement: adım 2, 2 resimden 1. BlackBerry 7280 Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Logic Board Replacement, SIM Card: adım 3, 3 resimden 1. BlackBerry 7280 Logic Board Replacement, SIM Card: adım 3, 3 resimden 2. BlackBerry 7280 Logic Board Replacement, SIM Card: adım 3, 3 resimden 3.
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Logic Board Replacement, Back Case: adım 4, 2 resimden 1. BlackBerry 7280 Logic Board Replacement, Back Case: adım 4, 2 resimden 2.
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Logic Board Replacement: adım 5, 2 resimden 1. BlackBerry 7280 Logic Board Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Logic Board Replacement, Front Case: adım 6, 2 resimden 1. BlackBerry 7280 Logic Board Replacement, Front Case: adım 6, 2 resimden 2.
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Logic Board Replacement: adım 7, 2 resimden 1. BlackBerry 7280 Logic Board Replacement: adım 7, 2 resimden 2.
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 Logic Board Replacement, LCD Screen and Speaker: adım 8, 2 resimden 1. BlackBerry 7280 Logic Board Replacement, LCD Screen and Speaker: adım 8, 2 resimden 2.
    • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
  9. BlackBerry 7280 Logic Board Replacement, Logic Board: adım 9, 1 resimden 1.
    • Use a Torx T6 screwdriver to remove the 3 1/8 inch screws shown.
  10. BlackBerry 7280 Logic Board Replacement: adım 10, 1 resimden 1.
    • Remove the logic board with your hands.
Sonuç
Sarah Waddill
10 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G2
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 393
