Ana içeriğe geç
BlackBerry 7280 Microphone Replacement
Neye ihtiyacın var
    1. BlackBerry 7280 Microphone Replacement, Battery: adım 1, 3 resimden 1. BlackBerry 7280 Microphone Replacement, Battery: adım 1, 3 resimden 2. BlackBerry 7280 Microphone Replacement, Battery: adım 1, 3 resimden 3.
      • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
      • Slide the battery cover off the device.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7280 Microphone Replacement: adım 2, 2 resimden 1. BlackBerry 7280 Microphone Replacement: adım 2, 2 resimden 2.
      • Remove the lithium-ion battery from the back of the device using your index finger.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, SIM Card: adım 3, 3 resimden 1. BlackBerry 7280 Microphone Replacement, SIM Card: adım 3, 3 resimden 2. BlackBerry 7280 Microphone Replacement, SIM Card: adım 3, 3 resimden 3.
      • Hold the device with both hands.
      • Lift the SIM card holder using your thumb and index finger.
      • Remove the SIM card from the device.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, Back Case: adım 4, 2 resimden 1. BlackBerry 7280 Microphone Replacement, Back Case: adım 4, 2 resimden 2.
      • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
      • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7280 Microphone Replacement: adım 5, 2 resimden 1. BlackBerry 7280 Microphone Replacement: adım 5, 2 resimden 2.
      • Use the plastic opening tool to pry the back case away from the front case.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, Front Case: adım 6, 2 resimden 1. BlackBerry 7280 Microphone Replacement, Front Case: adım 6, 2 resimden 2.
      • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7280 Microphone Replacement: adım 7, 2 resimden 1. BlackBerry 7280 Microphone Replacement: adım 7, 2 resimden 2.
      • Remove the front plastic case from the metal bracket.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, LCD Screen and Speaker: adım 8, 2 resimden 1. BlackBerry 7280 Microphone Replacement, LCD Screen and Speaker: adım 8, 2 resimden 2.
      • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, Logic Board: adım 9, 1 resimden 1.
      • Use a Torx T6 screwdriver to remove the 3 1/8 inch screws shown.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry 7280 Microphone Replacement: adım 10, 1 resimden 1.
      • Remove the logic board with your hands.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry 7280 Microphone Replacement, Microphone: adım 11, 3 resimden 1. BlackBerry 7280 Microphone Replacement, Microphone: adım 11, 3 resimden 2. BlackBerry 7280 Microphone Replacement, Microphone: adım 11, 3 resimden 3.
      • Remove the small black rubber microphone by sliding it off of the metal bracket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Catlin
16 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G2
4 Üyeler
90 adet Kılavuz yazıldı
1Rehber Yorum
Hi ! great tutorial ! do you know the reference name or number of the microphone that this blackberry uses ?
Thank you !
DearTom - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 610
