Ana içeriğe geç
BlackBerry 7290 Keypad Replacement
Neye ihtiyacın var
  1. BlackBerry 7290 Keypad Replacement, Battery: adım 1, 3 resimden 1. BlackBerry 7290 Keypad Replacement, Battery: adım 1, 3 resimden 2. BlackBerry 7290 Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 Keypad Replacement: adım 2, 3 resimden 1. BlackBerry 7290 Keypad Replacement: adım 2, 3 resimden 2. BlackBerry 7290 Keypad Replacement: adım 2, 3 resimden 3.
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 Keypad Replacement, SIM Card: adım 3, 1 resimden 1.
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 Keypad Replacement: adım 4, 2 resimden 1. BlackBerry 7290 Keypad Replacement: adım 4, 2 resimden 2.
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 Keypad Replacement, Side Button: adım 5, 1 resimden 1.
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 Keypad Replacement: adım 6, 2 resimden 1. BlackBerry 7290 Keypad Replacement: adım 6, 2 resimden 2.
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 Keypad Replacement: adım 7, 1 resimden 1.
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 Keypad Replacement: adım 8, 3 resimden 1. BlackBerry 7290 Keypad Replacement: adım 8, 3 resimden 2. BlackBerry 7290 Keypad Replacement: adım 8, 3 resimden 3.
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 Keypad Replacement: adım 9, 2 resimden 1. BlackBerry 7290 Keypad Replacement: adım 9, 2 resimden 2.
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. BlackBerry 7290 Keypad Replacement, Keypad: adım 10, 1 resimden 1.
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. BlackBerry 7290 Keypad Replacement: adım 11, 1 resimden 1.
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. BlackBerry 7290 Keypad Replacement: adım 12, 1 resimden 1.
    • Turn the internals over to reveal the LCD display.
  13. BlackBerry 7290 Keypad Replacement: adım 13, 2 resimden 1. BlackBerry 7290 Keypad Replacement: adım 13, 2 resimden 2.
    • Peel off the rubber keypad buttons from the face plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
kmathew
3 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-6, Maness Fall 2009 Cal Poly, Team 19-6, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G6
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 3,871
