Ana içeriğe geç
BlackBerry 7510 Keypad Replacement
Neye ihtiyacın var
  1. BlackBerry 7510 Keypad Replacement, Back Face of Phone: adım 1, 1 resimden 1.
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Keypad Replacement: adım 2, 1 resimden 1.
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Keypad Replacement: adım 3, 1 resimden 1.
    • Lift off the back cover.
  4. BlackBerry 7510 Keypad Replacement: adım 4, 1 resimden 1.
    • Remove the two T6 screws.
  5. BlackBerry 7510 Keypad Replacement: adım 5, 2 resimden 1. BlackBerry 7510 Keypad Replacement: adım 5, 2 resimden 2.
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Keypad Replacement, Keypad: adım 6, 3 resimden 1. BlackBerry 7510 Keypad Replacement, Keypad: adım 6, 3 resimden 2. BlackBerry 7510 Keypad Replacement, Keypad: adım 6, 3 resimden 3.
    • Unscrew metal plate.
    • Pry off front cover.
    • Lift off front cover to expose LCD screen.
  7. BlackBerry 7510 Keypad Replacement: adım 7, 1 resimden 1.
    • Remove keypad from front cover and replace or fix existing pad.
Sonuç
Neil Johnson
12 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G44
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,545
