Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the six T6 Torx screws on the back of the phone.
Make sure to keep the screws somewhere that they will not get lost.
Using your finger nail or a spudger, carefully pry up the back cover.
Begin in one spot and slowly circle around the device as you pry up all of the back cover.
Remove the daughterboard.
Remove the exposed vibration motor.
Unscrew metal plate.
Pry off front cover.
Lift off front cover to expose LCD screen.
Remove keypad from front cover and replace or fix existing pad.
