Ana içeriğe geç
BlackBerry 7510 Logic Board Replacement
Neye ihtiyacın var
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: adım 1, 1 resimden 1.
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: adım 2, 1 resimden 1.
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: adım 3, 1 resimden 1.
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: adım 4, 1 resimden 1.
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: adım 5, 2 resimden 1. BlackBerry 7510 Logic Board Replacement: adım 5, 2 resimden 2.
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: adım 6, 1 resimden 1.
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: adım 7, 1 resimden 1.
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: adım 8, 1 resimden 1.
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: adım 9, 1 resimden 1.
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: adım 10, 2 resimden 1. BlackBerry 7510 Logic Board Replacement: adım 10, 2 resimden 2.
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: adım 11, 2 resimden 1. BlackBerry 7510 Logic Board Replacement: adım 11, 2 resimden 2.
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
Sonuç
Neil Johnson
12 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G44
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,867
