Ana içeriğe geç
BlackBerry 8700c Replacing Logic Board Replacement
Neye ihtiyacın var
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: adım 1, 2 resimden 1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: adım 1, 2 resimden 2.
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: adım 2, 2 resimden 1. BlackBerry 8700c Replacing Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: adım 3, 1 resimden 1.
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: adım 4, 2 resimden 1. BlackBerry 8700c Replacing Logic Board Replacement: adım 4, 2 resimden 2.
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: adım 5, 2 resimden 1. BlackBerry 8700c Replacing Logic Board Replacement: adım 5, 2 resimden 2.
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: adım 6, 3 resimden 1. BlackBerry 8700c Replacing Logic Board Replacement: adım 6, 3 resimden 2. BlackBerry 8700c Replacing Logic Board Replacement: adım 6, 3 resimden 3.
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
Sonuç
arlebrun
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,225
