Ana içeriğe geç
BlackBerry 8703e Battery Replacement
Neye ihtiyacın var
  1. BlackBerry 8703e Battery Replacement, Battery: adım 1, 2 resimden 1. BlackBerry 8703e Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: adım 2, 1 resimden 1.
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
Sonuç
Johnathon Gorski
22 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-3, Forte Winter 2010 Cal Poly, Team 11-3, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G3
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 3,417
