Ana içeriğe geç
BlackBerry 8820 LCD Screen Replacement
Neye ihtiyacın var
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: adım 2, 2 resimden 1. BlackBerry 8820 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: adım 3, 2 resimden 1. BlackBerry 8820 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: adım 6, 1 resimden 1.
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: adım 7, 2 resimden 1. BlackBerry 8820 LCD Screen Replacement: adım 7, 2 resimden 2.
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: adım 8, 2 resimden 1. BlackBerry 8820 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: adım 9, 2 resimden 1. BlackBerry 8820 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
Sonuç
ryan
44 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G64
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 782
