Ana içeriğe geç
BlackBerry 8820 Motherboard Replacement
Neye ihtiyacın var
  1. BlackBerry 8820 Motherboard Replacement, Disassembling BlackBerry 8820 Outer Casing: adım 1, 1 resimden 1.
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Motherboard Replacement: adım 2, 2 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: adım 3, 2 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Motherboard Replacement: adım 5, 1 resimden 1.
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. BlackBerry 8820 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the bottom casing clip, it will easily unsnap when pulled
  7. BlackBerry 8820 Motherboard Replacement: adım 7, 2 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 7, 2 resimden 2.
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
  8. BlackBerry 8820 Motherboard Replacement: adım 8, 2 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 8, 2 resimden 2.
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector
    • When removing the ribbon cable handle with care; it is prone to breaking
  9. BlackBerry 8820 Motherboard Replacement: adım 9, 2 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 9, 2 resimden 2.
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
    • Using the prying tool, lever up the old screen as shown.
  10. BlackBerry 8820 Motherboard Replacement: adım 10, 3 resimden 1. BlackBerry 8820 Motherboard Replacement: adım 10, 3 resimden 2. BlackBerry 8820 Motherboard Replacement: adım 10, 3 resimden 3.
    • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
    • After you remove the old motherboard, you can then replace it with a new one.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ryan
44 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G64
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 906
