Ana içeriğe geç
BlackBerry 8820 Trackball Replacement
Neye ihtiyacın var
  1. BlackBerry 8820 Trackball Replacement, Disassembling BlackBerry 8820 Outer Casing: adım 1, 1 resimden 1.
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Trackball Replacement: adım 2, 2 resimden 1. BlackBerry 8820 Trackball Replacement: adım 2, 2 resimden 2.
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Trackball Replacement: adım 3, 2 resimden 1. BlackBerry 8820 Trackball Replacement: adım 3, 2 resimden 2.
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Trackball Replacement: adım 4, 1 resimden 1.
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Trackball Replacement: adım 5, 1 resimden 1.
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Trackball Replacement, Track Ball: adım 6, 1 resimden 1.
    • After removing the front from the outer casing, the track ball will come off attached to the casing.
  7. BlackBerry 8820 Trackball Replacement: adım 7, 1 resimden 1.
    • Remove the track ball from the front case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ryan
44 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G64
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 852
