Ana içeriğe geç
BlackBerry Bold 9700 Keyboard Replacement
Neye ihtiyacın var
  1. BlackBerry Bold 9700 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the back panel by sliding it downward and lifting it away from the phone.
  2. BlackBerry Bold 9700 Keyboard Replacement: adım 2, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 2, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 2, 3 resimden 3.
    • Remove the battery by lifting the bottom edge of the battery from the bottom of the phone and up from the case.
    • (Warning: Power-off the device before removing the battery.)
  3. BlackBerry Bold 9700 Keyboard Replacement: adım 3, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 3, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 3, 3 resimden 3.
    • Remove the SIM card by pushing the card vertically through the bracket towards the top of the device.
    • The SIM card MUST be removed to disassemble the device.
  4. BlackBerry Bold 9700 Keyboard Replacement: adım 4, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 4, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to gently pry the bottom panel with the AT&T logo away from the phone.
    • Note: You will hear a snapping sound.
  5. BlackBerry Bold 9700 Keyboard Replacement: adım 5, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 5, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 5, 3 resimden 3.
    • Remove the front panel 5.57mm Torx head screws x2 with the T5 Torx screwdriver.
  6. BlackBerry Bold 9700 Keyboard Replacement: adım 6, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 6, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the plastic opening tool to remove the frame.
    • This will take a bit of effort. You will hear a snapping sound.
  7. BlackBerry Bold 9700 Keyboard Replacement: adım 7, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 7, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 7, 3 resimden 3.
    • Gently lift the bottom of the keyboard up with your fingers and pull it toward the bottom of the phone.
  8. BlackBerry Bold 9700 Keyboard Replacement: adım 8, 3 resimden 1. BlackBerry Bold 9700 Keyboard Replacement: adım 8, 3 resimden 2. BlackBerry Bold 9700 Keyboard Replacement: adım 8, 3 resimden 3.
    • Align the new keyboard to the bottom of the screen with the track pad slot angled downward.
    • Once the keyboard is flush with the screen, push the keyboard into place.
Sonuç
To reassemble your device, follow these steps in reverse.
Danny
365 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-3, Panko Spring 2015 Colorado Springs, Team 9-3, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G3
2 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,271
