Ana içeriğe geç
BlackBerry Bold 9700 Trackpad Replacement
Neye ihtiyacın var
    1. BlackBerry Bold 9700 Trackpad Replacement, Motherboard Housing: adım 1, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement, Motherboard Housing: adım 1, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement, Motherboard Housing: adım 1, 3 resimden 3.
      • Remove the battery by prying the bottom of the battery upward.
      • Once the battery is angled up, pull it away from the top of the device.
      • Be sure to remove all power sources before working on electronic devices to avoid harming yourself or the device.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Bold 9700 Trackpad Replacement: adım 2, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 2, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 2, 3 resimden 3.
      • Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
      • You must remove the SIM card before you can fully disassemble the device. Failure to do so may cause damage to components later on in this process.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry Bold 9700 Trackpad Replacement: adım 3, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 3, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 3, 3 resimden 3.
      • Pry off the AT&T logo panel with the plastic opening tool.
      • You will hear a snapping sound as the plastic tabs pop out.
      FixBot'a Sor
      Yorum Ekle
    4. BlackBerry Bold 9700 Trackpad Replacement: adım 4, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 4, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 4, 3 resimden 3.
      • Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
      FixBot'a Sor
      Yorum Ekle
    5. BlackBerry Bold 9700 Trackpad Replacement: adım 5, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 5, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 5, 3 resimden 3.
      • Use the plastic opening tool to remove the frame of your device.
      • You will hear a snapping sound as the tabs pop out.
      • Once the case is loosened from the device, slide the case away from the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. BlackBerry Bold 9700 Trackpad Replacement: adım 6, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 6, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 6, 3 resimden 3.
      • Gently lift the bottom of the keyboard upward.
      • Pull the keyboard away from the bottom of the LCD display and lift upward.
      FixBot'a Sor
      Yorum Ekle
    7. BlackBerry Bold 9700 Trackpad Replacement: adım 7, 2 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 7, 2 resimden 2.
      • Remove the two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. BlackBerry Bold 9700 Trackpad Replacement: adım 8, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 8, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 8, 3 resimden 3.
      • Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
      • Ribbon connectors are fragile. Too much force in the wrong place will damage the ribbon and may force you to replace an entire assembly.
      FixBot'a Sor
      Yorum Ekle
    9. BlackBerry Bold 9700 Trackpad Replacement: adım 9, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 9, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 9, 3 resimden 3.
      • Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
      • You should now have two 5.57mm black torx head screws and four 4.13mm steel Torx head screws off to the side. Do not lose them.
      • Lift the clear plastic cover directly upward.
      FixBot'a Sor
      Yorum Ekle
    10. BlackBerry Bold 9700 Trackpad Replacement: adım 10, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 10, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 10, 3 resimden 3.
      • Grip the motherboard by the screen
      • Lift the board away from the base of the housing and vertically up.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry Bold 9700 Trackpad Replacement, Trackpad: adım 11, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement, Trackpad: adım 11, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement, Trackpad: adım 11, 3 resimden 3.
      • Flip the board over so that the LCD display is against the the surface of your work space.
      • Use a plastic opening tool to gently remove the ribbon connector located on the right-hand side of the board.
      • Ribbon cables are fragile. Be gentle when working with ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Bold 9700 Trackpad Replacement: adım 12, 2 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 12, 2 resimden 2.
      • Gently grip the trackpad.
      • Pull the ribbon cable through the slot in the board.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry Bold 9700 Trackpad Replacement: adım 13, 3 resimden 1. BlackBerry Bold 9700 Trackpad Replacement: adım 13, 3 resimden 2. BlackBerry Bold 9700 Trackpad Replacement: adım 13, 3 resimden 3.
      • Insert the ribbon connector of your new trackpad through the slot in the board.
      • Align the ribbon connector with the connection point.
      • Gently press the ribbon connector into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Patrick
703 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-3, Panko Spring 2015 Colorado Springs, Team 9-3, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G3
2 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 51
Her zaman: 1,823
