Ana içeriğe geç
BlackBerry Curve 8310 Keyboard Replacement
Neye ihtiyacın var
    1. BlackBerry Curve 8310 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Press down on the battery release button and slide the back cover up with your thumb.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8310 Keyboard Replacement: adım 2, 1 resimden 1.
      • Pry from the top of the battery to pull it out.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry Curve 8310 Keyboard Replacement, Lens: adım 3, 1 resimden 1.
      • Slide the metal sim card cover to the unlock position.
      • Remove the sim card.
      • The arrows on the sim card enclosure indicate the lock and unlock positions.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8310 Keyboard Replacement: adım 4, 1 resimden 1.
      • Remove the two T5 Torx screws circled at the top of the phone.
      • The T5 Torx screws may be covered by a white sticker.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry Curve 8310 Keyboard Replacement: adım 5, 1 resimden 1.
      • Remove the red cover at the bottom of the phone.
      • You may have to work a spudger underneath to release the plastic clips.
      FixBot'a Sor
      Yorum Ekle
    4. BlackBerry Curve 8310 Keyboard Replacement: adım 6, 3 resimden 1. BlackBerry Curve 8310 Keyboard Replacement: adım 6, 3 resimden 2. BlackBerry Curve 8310 Keyboard Replacement: adım 6, 3 resimden 3.
      • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
      • Use a spudger to pry the front cover away from the side panels.
      • Work the spudger around the entire phone until the front cover is free.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry Curve 8310 Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
      • Remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mandy Chan
91 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G32
4 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 2,272
