Ana içeriğe geç
BlackBerry Curve 8310 LCD Screen Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8310 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 LCD Screen Replacement, Lens: adım 3, 1 resimden 1.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 LCD Screen Replacement: adım 6, 3 resimden 1. BlackBerry Curve 8310 LCD Screen Replacement: adım 6, 3 resimden 2. BlackBerry Curve 8310 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 LCD Screen Replacement, Keyboard: adım 7, 1 resimden 1.
    • Remove the keyboard.
  8. BlackBerry Curve 8310 LCD Screen Replacement, Screen Housing: adım 8, 1 resimden 1.
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. BlackBerry Curve 8310 LCD Screen Replacement: adım 9, 2 resimden 1. BlackBerry Curve 8310 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Now remove the left and right side panels.
  10. BlackBerry Curve 8310 LCD Screen Replacement: adım 10, 3 resimden 1. BlackBerry Curve 8310 LCD Screen Replacement: adım 10, 3 resimden 2. BlackBerry Curve 8310 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. BlackBerry Curve 8310 LCD Screen Replacement, LCD Screen: adım 11, 1 resimden 1.
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. BlackBerry Curve 8310 LCD Screen Replacement: adım 12, 1 resimden 1.
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mandy Chan
91 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G32
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 1,799
