Ana içeriğe geç
BlackBerry Curve 8310 Lens Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8310 Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 Lens Replacement: adım 2, 1 resimden 1.
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 Lens Replacement, Lens: adım 3, 1 resimden 1.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 Lens Replacement: adım 4, 1 resimden 1.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 Lens Replacement: adım 5, 1 resimden 1.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 Lens Replacement: adım 6, 3 resimden 1. BlackBerry Curve 8310 Lens Replacement: adım 6, 3 resimden 2. BlackBerry Curve 8310 Lens Replacement: adım 6, 3 resimden 3.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
Sonuç
Sean Willis
229 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G32
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 975
