Ana içeriğe geç
BlackBerry Curve 8520 Motherboard Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: adım 2, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement, Battery: adım 2, 2 resimden 2.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: adım 3, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: adım 3, 2 resimden 2.
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: adım 4, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement: adım 4, 2 resimden 2.
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: adım 5, 3 resimden 1. BlackBerry Curve 8520 Motherboard Replacement: adım 5, 3 resimden 2. BlackBerry Curve 8520 Motherboard Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: adım 6, 3 resimden 1. BlackBerry Curve 8520 Motherboard Replacement: adım 6, 3 resimden 2. BlackBerry Curve 8520 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
    bb is nt a freely phone is a phone bcz of ringing some how it is nt
    tankiso - Yanıt
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: adım 8, 2 resimden 1. BlackBerry Curve 8520 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
Matt
1.722 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G62
5 Üyeler
Bir Yorum
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 36,794
