Ana içeriğe geç
BlackBerry Curve 8530 Keypad Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: adım 1, 2 resimden 1. BlackBerry Curve 8530 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Keypad Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: adım 3, 2 resimden 1. BlackBerry Curve 8530 Keypad Replacement, Keypad: adım 3, 2 resimden 2.
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Keypad Replacement: adım 4, 2 resimden 1. BlackBerry Curve 8530 Keypad Replacement: adım 4, 2 resimden 2.
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Keypad Replacement: adım 5, 3 resimden 1. BlackBerry Curve 8530 Keypad Replacement: adım 5, 3 resimden 2. BlackBerry Curve 8530 Keypad Replacement: adım 5, 3 resimden 3.
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Keypad Replacement: adım 6, 2 resimden 1. BlackBerry Curve 8530 Keypad Replacement: adım 6, 2 resimden 2.
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
Sonuç
To reassemble the device, follow the instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Cory Davis
503 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G13
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 6,397
