Ana içeriğe geç
BlackBerry Curve 8530 Screen Replacement
Neye ihtiyacın var
    1. BlackBerry Curve 8530 Screen Replacement, Battery: adım 1, 2 resimden 1. BlackBerry Curve 8530 Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Place the phone on a flat surface with the screen facing down.
      • Remove the plastic backplate by pulling up on the bottom of the cover.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8530 Screen Replacement: adım 2, 1 resimden 1.
      • Remove the battery by pulling up from the top of the battery.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry Curve 8530 Screen Replacement, Keypad: adım 3, 2 resimden 1. BlackBerry Curve 8530 Screen Replacement, Keypad: adım 3, 2 resimden 2.
      • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
      • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8530 Screen Replacement: adım 4, 2 resimden 1. BlackBerry Curve 8530 Screen Replacement: adım 4, 2 resimden 2.
      • Flip the phone over so the keyboard faces up.
      • Insert a plastic spudger into the screen where speaker resides.
      • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
      • Gently lift up plastic screen cover until screen cover separates from screen.
      • Continue until screen cover is completely removed.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry Curve 8530 Screen Replacement: adım 5, 3 resimden 1. BlackBerry Curve 8530 Screen Replacement: adım 5, 3 resimden 2. BlackBerry Curve 8530 Screen Replacement: adım 5, 3 resimden 3.
      • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
      • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
      FixBot'a Sor
      Yorum Ekle
    4. BlackBerry Curve 8530 Screen Replacement: adım 6, 2 resimden 1. BlackBerry Curve 8530 Screen Replacement: adım 6, 2 resimden 2.
      • The keyboard should slide off of the phone now that the plastic siding has been removed.
      FixBot'a Sor
      Yorum Ekle
    1. BlackBerry Curve 8530 Screen Replacement, Screen: adım 7, 3 resimden 1. BlackBerry Curve 8530 Screen Replacement, Screen: adım 7, 3 resimden 2. BlackBerry Curve 8530 Screen Replacement, Screen: adım 7, 3 resimden 3.
      • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
      • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
      • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8530 Screen Replacement: adım 8, 3 resimden 1. BlackBerry Curve 8530 Screen Replacement: adım 8, 3 resimden 2. BlackBerry Curve 8530 Screen Replacement: adım 8, 3 resimden 3.
      • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
      • Use pressure to unlatch the screen from the clips.
      • Now that these clips have been undone, the screen should lift up easily.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Michael Labdon
259 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G13
3 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 8,304
