Ana içeriğe geç
BlackBerry Curve 8900 Case Replacement
Neye ihtiyacın var
    1. BlackBerry Curve 8900 Case Replacement, Removing the Case: adım 1, 2 resimden 1. BlackBerry Curve 8900 Case Replacement, Removing the Case: adım 1, 2 resimden 2.
      • Remove the rear cover from the phone.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: adım 2, 1 resimden 1.
      • Using a small plastic opening tool, remove the lower rear cover.
      FixBot'a Sor
      Yorum Ekle
    3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: adım 3, 1 resimden 1.
      • Remove the six screws from the midframe of the device.
      • Be careful not to damage the screws while removing them.
      FixBot'a Sor
      Yorum Ekle
    4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: adım 4, 1 resimden 1.
      • Remove the midframe from the phone.
      FixBot'a Sor
      Yorum Ekle
    5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: adım 5, 2 resimden 1. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: adım 5, 2 resimden 2.
      • Gently pry the back the plastic tabs that secure the motherboard to the case.
      • Slowly work your way around the case with the tabs until the motherboard comes free.
      • Remove the motherboard.
      • The keypad and navigation ball may become loose and fall away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Use the new case and reassemble the phone by doing the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Renae Bishop
68 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G3
3 Üyeler
56 adet Kılavuz yazıldı
1Rehber Yorum
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 3,759
