Ana içeriğe geç
BlackBerry Curve 8900 Case Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: adım 1, 2 resimden 1. BlackBerry Curve 8900 Case Replacement, Removing the Case: adım 1, 2 resimden 2.
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: adım 2, 1 resimden 1.
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: adım 3, 1 resimden 1.
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: adım 4, 1 resimden 1.
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: adım 5, 2 resimden 1. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: adım 5, 2 resimden 2.
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Sonuç
Use the new case and reassemble the phone by doing the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Renae Bishop
68 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G3
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 3,312
