Ana içeriğe geç
BlackBerry Curve 8900 Keypad Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: adım 1, 1 resimden 1.
    • Remove the back cover and the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: adım 2, 1 resimden 1.
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
    FixBot'a Sor
    Yorum Ekle
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: adım 3, 1 resimden 1.
    • Remove all six T6 screws from the midframe.
    FixBot'a Sor
    Yorum Ekle
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: adım 4, 1 resimden 1.
    • Separate the midframe from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: adım 5, 1 resimden 1.
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: adım 6, 3 resimden 1. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: adım 6, 3 resimden 2. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: adım 6, 3 resimden 3.
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Renae Bishop
68 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G3
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 7,437
