Ana içeriğe geç
BlackBerry Curve 8900 Microphone Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
    FixBot'a Sor
  2. BlackBerry Curve 8900 Microphone Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Using the iFixit Opening Tool, remove the lower rear cover.
    FixBot'a Sor
  3. BlackBerry Curve 8900 Microphone Replacement: adım 3, 1 resimden 1.
    T6 Torx Screwdriver
    $9.99
    FixBot'a Sor
  4. BlackBerry Curve 8900 Microphone Replacement: adım 4, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    FixBot'a Sor
  5. BlackBerry Curve 8900 Microphone Replacement: adım 5, 2 resimden 1. BlackBerry Curve 8900 Microphone Replacement: adım 5, 2 resimden 2.
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
    FixBot'a Sor
  6. BlackBerry Curve 8900 Microphone Replacement: adım 6, 1 resimden 1.
    • With your fingers, carefully remove the screen so as not to damage it.
    FixBot'a Sor
  7. BlackBerry Curve 8900 Microphone Replacement: adım 7, 2 resimden 1. BlackBerry Curve 8900 Microphone Replacement: adım 7, 2 resimden 2.
    • With your fingers, carefully unhook the antenna cable in all three locations.
    FixBot'a Sor
  8. BlackBerry Curve 8900 Microphone Replacement: adım 8, 1 resimden 1.
    Spudger
    $3.99
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
    FixBot'a Sor
  9. BlackBerry Curve 8900 Microphone Replacement: adım 9, 1 resimden 1.
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
    FixBot'a Sor
  10. BlackBerry Curve 8900 Microphone Replacement: adım 10, 2 resimden 1. BlackBerry Curve 8900 Microphone Replacement: adım 10, 2 resimden 2.
    • Replace the entire motherboard to replace the microphone.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnny Tran
473 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 70
Her zaman: 4,801
