Ana içeriğe geç
BlackBerry Curve 8900 Motherboard Replacement
Neye ihtiyacın var
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: adım 2, 2 resimden 1. BlackBerry Curve 8900 Motherboard Replacement: adım 2, 2 resimden 2.
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Motherboard Replacement: adım 6, 2 resimden 1. BlackBerry Curve 8900 Motherboard Replacement: adım 6, 2 resimden 2.
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: adım 7, 2 resimden 1. BlackBerry Curve 8900 Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Motherboard Replacement: adım 8, 1 resimden 1.
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: adım 9, 2 resimden 1. BlackBerry Curve 8900 Motherboard Replacement: adım 9, 2 resimden 2.
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Motherboard Replacement: adım 10, 2 resimden 1. BlackBerry Curve 8900 Motherboard Replacement: adım 10, 2 resimden 2.
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Johnny Tran
473 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 4,081
