Ana içeriğe geç
BlackBerry Key2 Disassembly
  1. BlackBerry Key2 Disassembly, Blackberry Key2: adım 1, 3 resimden 1. BlackBerry Key2 Disassembly, Blackberry Key2: adım 1, 3 resimden 2. BlackBerry Key2 Disassembly, Blackberry Key2: adım 1, 3 resimden 3.
    • The start of our disassembly. Turn off your device before start.
    • Remove the sim card bracket.
    FixBot'a Sor
    Yorum Ekle
  2. BlackBerry Key2 Disassembly, Heating process: adım 2, 3 resimden 1. BlackBerry Key2 Disassembly, Heating process: adım 2, 3 resimden 2. BlackBerry Key2 Disassembly, Heating process: adım 2, 3 resimden 3.
    • Apply heat to the back of the phone to remove the plastic cover.
    • With a pry tool of your preference start to lift up the back cover. Be careful on that part of the process.
    FixBot'a Sor
    Yorum Ekle
  3. BlackBerry Key2 Disassembly, Removing the screws: adım 3, 3 resimden 1. BlackBerry Key2 Disassembly, Removing the screws: adım 3, 3 resimden 2. BlackBerry Key2 Disassembly, Removing the screws: adım 3, 3 resimden 3.
    • Remove all the screws.
    • Remove the loudspeaker module.
    FixBot'a Sor
    Yorum Ekle
  4. BlackBerry Key2 Disassembly, Antenna cable: adım 4, 3 resimden 1. BlackBerry Key2 Disassembly, Antenna cable: adım 4, 3 resimden 2. BlackBerry Key2 Disassembly, Antenna cable: adım 4, 3 resimden 3.
    • Use the point of a plastic spudger to lift the antenna cable connector up off of its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  5. BlackBerry Key2 Disassembly, Back bracket: adım 5, 3 resimden 1. BlackBerry Key2 Disassembly, Back bracket: adım 5, 3 resimden 2. BlackBerry Key2 Disassembly, Back bracket: adım 5, 3 resimden 3.
    • Be gentle lifting up the back bracket.
    • I marked in red all the flex cables connected on the motherboard. You got to remove them all.
    • Start disconnecting the battery flex cable.
    FixBot'a Sor
    Yorum Ekle
  6. BlackBerry Key2 Disassembly, Removing the flex cables: adım 6, 3 resimden 1. BlackBerry Key2 Disassembly, Removing the flex cables: adım 6, 3 resimden 2. BlackBerry Key2 Disassembly, Removing the flex cables: adım 6, 3 resimden 3.
    • Disconnect and remove the rear camera.
    • Then continue disconnecting the other flex cables.
    • Don't forget to use a plastic tool.
    FixBot'a Sor
    Yorum Ekle
  7. BlackBerry Key2 Disassembly, Removing the motherboard.: adım 7, 3 resimden 1. BlackBerry Key2 Disassembly, Removing the motherboard.: adım 7, 3 resimden 2. BlackBerry Key2 Disassembly, Removing the motherboard.: adım 7, 3 resimden 3.
    • Disconnect all the flex cables.
    • Start from the bottom .
    • Lift up gentle and check the last photo,there's a little detail on the proximity sensor. You'll have to disconnect it after lift up the motherboard.
    • Observation : this way worked better for me without damaging the proximity sensor. It doesn't change anything try to heat up a little bit and removing it before remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. BlackBerry Key2 Disassembly, Removing the LCD.: adım 8, 3 resimden 1. BlackBerry Key2 Disassembly, Removing the LCD.: adım 8, 3 resimden 2. BlackBerry Key2 Disassembly, Removing the LCD.: adım 8, 3 resimden 3.
    • Heat the LCD before lift.
    FixBot'a Sor
    Yorum Ekle
  9. BlackBerry Key2 Disassembly, Final: adım 9, 1 resimden 1.
    • And we're done.
    FixBot'a Sor
    Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
DouglasVinicio
1.699 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
The antenna connector on the daughter board can be broken off really easily. Pop off the connectors carefully. A hot air workstation will make quick work of re attaching tho.
Grant Marshall - Yanıt Paylaş
OMG that’s probably exactly what happened to me. now the phone does not receive network anymore any suggestions on what to do ?? i am quite certain i cannot get another antenna or board. do you think i can find a matching antenna from another phone entirely ???
Chinedu - Yanıt Paylaş
Thanks for this tear down! At what step can the battery be removed? It *appears* to be mid-step-5
charleslindsay - Yanıt Paylaş
Same her no Network so my Key2 ist useless :/
Christoph Alber - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 123
Her zaman: 18,356
