Ana içeriğe geç
BlackBerry KeyONE partial Disassembly
Neye ihtiyacın var
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: adım 1, 1 resimden 1.
    • Carefully remove the top plastic cover. It is held in place by adhesive.
    FixBot'a Sor
    Yorum Ekle
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: adım 2, 2 resimden 1. BlackBerry KeyONE partial Disassembly, Remove top frame: adım 2, 2 resimden 2.
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
    FixBot'a Sor
    Yorum Ekle
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: adım 3, 1 resimden 1.
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
    FixBot'a Sor
    Yorum Ekle
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: adım 4, 2 resimden 1. BlackBerry KeyONE partial Disassembly, Disconnect Battery: adım 4, 2 resimden 2.
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
    FixBot'a Sor
    Yorum Ekle
  5. BlackBerry KeyONE partial Disassembly: adım 5, 1 resimden 1.
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
    FixBot'a Sor
    Yorum Ekle
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: adım 6, 1 resimden 1.
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
    FixBot'a Sor
    Yorum Ekle
  7. BlackBerry KeyONE partial Disassembly: adım 7, 1 resimden 1.
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
raven
1.110 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 65
Her zaman: 10,930
