Ana içeriğe geç
BlackBerry Pearl 8100 Disassembly
Neye ihtiyacın var
  1. BlackBerry Pearl 8100 Disassembly, Rear Cover: adım 1, 1 resimden 1.
    • Push the button indicated by the yellow marker to remove the rear cover.
    • Remove the battery (not pictured).
  2. BlackBerry Pearl 8100 Disassembly, Screws underneath the rear cover: adım 2, 1 resimden 1.
    • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  3. BlackBerry Pearl 8100 Disassembly, Bottom Cover: adım 3, 2 resimden 1. BlackBerry Pearl 8100 Disassembly, Bottom Cover: adım 3, 2 resimden 2.
    • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  4. BlackBerry Pearl 8100 Disassembly, Side Cover: adım 4, 2 resimden 1. BlackBerry Pearl 8100 Disassembly, Side Cover: adım 4, 2 resimden 2.
    • Use the plastic opening tool to remove the side covers.
    • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  5. BlackBerry Pearl 8100 Disassembly, More screws: adım 5, 1 resimden 1.
    • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
    • Use the T6 Torx screwdriver to remove the screws.
  6. BlackBerry Pearl 8100 Disassembly, Frame: adım 6, 2 resimden 1. BlackBerry Pearl 8100 Disassembly, Frame: adım 6, 2 resimden 2.
    • With the screws removed, the frame can be detached.
  7. BlackBerry Pearl 8100 Disassembly, Logic Board: adım 7, 2 resimden 1. BlackBerry Pearl 8100 Disassembly, Logic Board: adım 7, 2 resimden 2.
    • Use the plastic opening tool to separate the motherboard from the front cover.
    • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  8. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: adım 8, 2 resimden 1. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: adım 8, 2 resimden 2.
    • Separate the keypad (first picture) and trackball (second picture) from the front cover.
    • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
    • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
  9. BlackBerry Pearl 8100 Disassembly, Complete: adım 9, 1 resimden 1.
    • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin
150 İtibar
2 adet Kılavuz yazıldı
Ekip
Aristotle Aristotle üyesi
Community
5 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 675
