Ana içeriğe geç
BlackBerry Pearl 8100 Logic Board Replacement
Neye ihtiyacın var
  1. BlackBerry Pearl 8100 Logic Board Replacement, Battery: adım 1, 1 resimden 1.
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Logic Board Replacement, Keyboard: adım 3, 1 resimden 1.
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Logic Board Replacement: adım 4, 2 resimden 1. BlackBerry Pearl 8100 Logic Board Replacement: adım 4, 2 resimden 2.
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Logic Board Replacement: adım 5, 1 resimden 1.
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Logic Board Replacement: adım 6, 1 resimden 1.
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Logic Board Replacement: adım 7, 2 resimden 1. BlackBerry Pearl 8100 Logic Board Replacement: adım 7, 2 resimden 2.
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Logic Board Replacement: adım 8, 1 resimden 1.
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Logic Board Replacement: adım 9, 2 resimden 1. BlackBerry Pearl 8100 Logic Board Replacement: adım 9, 2 resimden 2.
    • Gently remove the keyboard from front casing. It should snap out of place.
  9. BlackBerry Pearl 8100 Logic Board Replacement, Screen: adım 10, 1 resimden 1.
    • After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
  10. BlackBerry Pearl 8100 Logic Board Replacement, Logic Board: adım 11, 1 resimden 1.
    • To place the screen on the new logic board, place the golden-colored filament in the slot above the screen’s position, similar to how the old one was placed. There are two pegs that fit into the logic board and secure it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Robert Cronin
544 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-57, Forte Spring 2010 Cal Poly, Team 34-57, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G57
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 5,666
