Ana içeriğe geç
BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
Neye ihtiyacın var
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: adım 1, 3 resimden 1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: adım 1, 3 resimden 2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: adım 1, 3 resimden 3.
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 2, 3 resimden 1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 2, 3 resimden 2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 2, 3 resimden 3.
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 3, 3 resimden 1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 3, 3 resimden 2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 3, 3 resimden 3.
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 4, 3 resimden 1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 4, 3 resimden 2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 4, 3 resimden 3.
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 5, 3 resimden 1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 5, 3 resimden 2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: adım 5, 3 resimden 3.
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley
318 İtibar
3 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-5, Getto Spring 2013 SUNY Cortland, Team 1-5, Getto Spring 2013 üyesi
SUNYCORT-GETTO-S13S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 809
