Ana içeriğe geç
BlackBerry PlayBook Camera Replacement
Neye ihtiyacın var
  1. BlackBerry PlayBook Camera Replacement, Remove Back Panel: adım 1, 2 resimden 1. BlackBerry PlayBook Camera Replacement, Remove Back Panel: adım 1, 2 resimden 2.
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Camera Replacement, Motherboard: adım 2, 2 resimden 1. BlackBerry PlayBook Camera Replacement, Motherboard: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. BlackBerry PlayBook Camera Replacement: adım 3, 2 resimden 1. BlackBerry PlayBook Camera Replacement: adım 3, 2 resimden 2.
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. BlackBerry PlayBook Camera Replacement: adım 4, 2 resimden 1. BlackBerry PlayBook Camera Replacement: adım 4, 2 resimden 2.
  5. BlackBerry PlayBook Camera Replacement: adım 5, 2 resimden 1. BlackBerry PlayBook Camera Replacement: adım 5, 2 resimden 2.
  6. BlackBerry PlayBook Camera Replacement: adım 6, 3 resimden 1. BlackBerry PlayBook Camera Replacement: adım 6, 3 resimden 2. BlackBerry PlayBook Camera Replacement: adım 6, 3 resimden 3.
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. BlackBerry PlayBook Camera Replacement, Unscrew Motherboard: adım 7, 1 resimden 1.
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. BlackBerry PlayBook Camera Replacement, Remove Wire Leads: adım 8, 1 resimden 1.
  9. BlackBerry PlayBook Camera Replacement, Remove Motherboard: adım 9, 2 resimden 1. BlackBerry PlayBook Camera Replacement, Remove Motherboard: adım 9, 2 resimden 2.
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
  10. BlackBerry PlayBook Camera Replacement, Camera: adım 10, 1 resimden 1.
  11. BlackBerry PlayBook Camera Replacement, Remove Camera Assembly: adım 11, 2 resimden 1. BlackBerry PlayBook Camera Replacement, Remove Camera Assembly: adım 11, 2 resimden 2.
    • Pry the camera assembly away from the device, lifting the left side with a spudger.
    • There is a small hook on the right side of the assembly holding it in place. When removing the assembly, be sure to lift it from the left side in order to slide it out from under this hook.
  12. BlackBerry PlayBook Camera Replacement, Detach Plastic Frame from Cameras: adım 12, 2 resimden 1. BlackBerry PlayBook Camera Replacement, Detach Plastic Frame from Cameras: adım 12, 2 resimden 2.
    • Insert spudger between the plastic frame and circuit board.
    • Gently pry the plastic frame away from the rest of the camera assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan
682 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G27
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 3,754
