Ana içeriğe geç
BlackBerry PlayBook Speaker Replacement
Neye ihtiyacın var
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: adım 1, 2 resimden 1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: adım 1, 2 resimden 2.
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: adım 2, 1 resimden 1.
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: adım 3, 2 resimden 1. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: adım 3, 2 resimden 2.
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: adım 4, 2 resimden 1. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: adım 4, 2 resimden 2.
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: adım 5, 1 resimden 1.
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: adım 6, 2 resimden 1. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: adım 6, 2 resimden 2.
    • Lift the right speaker bar to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan
661 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G27
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 971
