Ana içeriğe geç
BlackBerry Storm 9530 Logic/Motherboard Replacement
Neye ihtiyacın var
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 2, 3 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 2, 3 resimden 2. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 2, 3 resimden 3.
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 4, 2 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 5, 3 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 5, 3 resimden 2. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 5, 3 resimden 3.
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 6, 3 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 6, 3 resimden 2. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 6, 3 resimden 3.
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 7, 1 resimden 1.
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 8, 2 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 8, 2 resimden 2.
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 9, 3 resimden 1. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 9, 3 resimden 2. BlackBerry Storm 9530 Logic/Motherboard Replacement: adım 9, 3 resimden 3.
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Josh Forester
2.582 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 9,604
