Ana içeriğe geç
BlackBerry Torch 9860 Handset Disassembly
Neye ihtiyacın var
  1. BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: adım 1, 2 resimden 1. BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: adım 1, 2 resimden 2.
    • Depress the battery cover release button and remove the battery cover
    • Remove the battery from the phone before continuing.
    • Slide the yellow button toward the battery to eject the SIM card
    • Remove the MicroSD card from the SD slot (if present)
  2. BlackBerry Torch 9860 Handset Disassembly: adım 2, 2 resimden 1. BlackBerry Torch 9860 Handset Disassembly: adım 2, 2 resimden 2.
    • There will be a silver bezel around the edge (the dog ate mine!)
    • Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
  3. BlackBerry Torch 9860 Handset Disassembly: adım 3, 2 resimden 1. BlackBerry Torch 9860 Handset Disassembly: adım 3, 2 resimden 2.
    • Grab your T5 Torx screwdriver, and remove all 8 screws
    • Be careful when taking out screws. The silver ones go in the corners, black ones in the middle
  4. BlackBerry Torch 9860 Handset Disassembly: adım 4, 2 resimden 1. BlackBerry Torch 9860 Handset Disassembly: adım 4, 2 resimden 2.
    • With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
    • Gently pry ribbon cable off, and then you will have the back cover fully removed
  5. BlackBerry Torch 9860 Handset Disassembly: adım 5, 3 resimden 1. BlackBerry Torch 9860 Handset Disassembly: adım 5, 3 resimden 2. BlackBerry Torch 9860 Handset Disassembly: adım 5, 3 resimden 3.
    • The next step is to remove the board.
    • There are 3 ribbon cables connected to it
    • Disconnect the first ribbon cable
    • When you remove the second ribbon cable it will reveal the third ribbon cable
  6. BlackBerry Torch 9860 Handset Disassembly: adım 6, 3 resimden 1. BlackBerry Torch 9860 Handset Disassembly: adım 6, 3 resimden 2. BlackBerry Torch 9860 Handset Disassembly: adım 6, 3 resimden 3.
    • With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
    • With the board removed, you can then simply lift out the LCD display
  7. BlackBerry Torch 9860 Handset Disassembly: adım 7, 1 resimden 1.
    • Once the LCD is removed, the handset disassembled.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
daniel
380 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 7,103
