Giriş
If your buttons are unresponsive or become difficult to push, then your keypad is probably damaged or dirty. Use these step-by-step instructions to replace your BlackBerry Tour 9630 keypad.
Neye ihtiyacın var
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Neredeyse bitti!
Sonuç
