Giriş
If your trackball is unresponsive or damaged, then you will need to replace it. Use these step-by-step instructions to replace your trackball on a Blackberry Tour 9630.
Neye ihtiyacın var
Position the phone so that the keyboard is facing down and the back is facing up.
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Bir başkası bu kılavuzu tamamladı.
