Giriş
Replace the internal Battery of this device
Neye ihtiyacın var
Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
Remove the SIM card and the Media SD card by pushing on them.
Use Plastic opening tools to separate the LCD from the Main body
Use a plastic tool to carefully switch up the LCD ribbon holder
Detach the LCD from the main board
With a plastic tool, untie the system board by detaching the ribbons attached to it
The battery ribbon is on the bottom right
Once all Ribbons untied, gently wiggle the system board out of the frame
10 farklı kişi bu kılavuzu tamamladı.
10 Yorum
Good guide, but one caveat - when removing the battery, the adhesive is pretty much directly attached to the NFC "plate" (a flexible square membrane with a pair of contacts on the bottom left side of the battery). If you try to extract the battery, you will have difficulty not destroying this membrane. Do not use a wedge - you must slowly remove the battery, preferably using a heat gun to loosen the glue.
Or get a battery already glued into a back plate.
Thank you for the detail. I will add a notice about that on the last step.
Hans -
