Ana içeriğe geç
BlackBerry Z30 Logic board Replacement
Neye ihtiyacın var
  1. BlackBerry Z30 Logic board Replacement, Battery cover: adım 1, 1 resimden 1.
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: adım 2, 1 resimden 1.
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: adım 3, 3 resimden 1. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: adım 3, 3 resimden 2. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: adım 3, 3 resimden 3.
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: adım 4, 2 resimden 1. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: adım 4, 2 resimden 2.
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: adım 5, 2 resimden 1. BlackBerry Z30 Logic board Replacement, Remove the LCD: adım 5, 2 resimden 2.
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: adım 6, 1 resimden 1.
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: adım 7, 1 resimden 1.
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: adım 8, 1 resimden 1.
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: adım 9, 1 resimden 1.
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: adım 10, 1 resimden 1.
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Hans
1.920 İtibar
6 adet Kılavuz yazıldı
Ekip
Mero IT Services Mero IT Services üyesi
Business
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 4,004
